![]() | Home > Maintenance & Mods (L322) > Battery drain ... once again! |
Could well be a faulty Final Stage Resistor, the component that controls the blower fan speed. Common problem causing battery drain.
lilico64 Member Since: 20 Mar 2021 Location: PAU Posts: 5 ![]() ![]() ![]() |
I had changed the hedgehog last year ... not easy ... but thanks for the tip: I start with the fuses and I'll see !! |
Hi, you were right: it's the fsr that fails ! I am disappointed by the short time that my replacement hedgehog has worked... : an idea or advice about the brand of the new one that I'll order ? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
IIRC the original was a Bosch... |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 731 ![]() ![]() ![]() |
I had 3 drains on my RR (look for my older posts as cant remember what they were). 1 was FSR, one was the BCU and cant remember the 3rd, maybe headlight washers?
