![]() | Home > Maintenance & Mods (L322) > Mats |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
The first one, more expensive one. Looks like what I’ve got in my my2010+ autobiography supercharger. The other cheaper version doesn’t. Perhaps it’s before 2010 or perhaps it’s non autobiography.
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 217 ![]() ![]() ![]() |
I’ve got the first ones in mine, they are the premium mats fitted from 2010-12. Although most of the time I’ve got the rubber mats in the front for general winter use and also when I go green laning. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
You chaps with the extra thick pricey ones - do these have the Range Rover emblem on them or just the metal corners? Current stable:
Mine just have the metal corners. They have about 1cm pile so very nice underfoot. |
No emblem, just the metal corners.
So are they these? Somehow they Look a bit cheap but if it is these guess that’s not the case when they are in?
Those look the same as mine, so I’d say yes.
Oh yes they do look great fitted what goes in the holes to fix them? Current stable:
The photo is very bad quality so hard to tell whether it is the genuine article or not. The original mats in the autobiography are anything but looking nor feeling cheap... |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
The LR AB "luxury carpet mats" have leather edging. The ones in the picture aren't those. The pile on the pictured mats looks a bit coarse by comparison with the genuine LR ones too. If you want your car to be 'right' then I'd avoid. Only Range Rovers since 1988 |
S it just a bad picture he is another the edging looks like it has white stitches not sure if this proves either way
Mine with the trim and stitching if it helps. Should have waterproof rubber backing as well.
Looking at the brochures I have (2011 RR and Accessories 2005) the premium mats (VPLMS0061PVA which is jet (black) and EAH000300PVA respectively) look different to your picture. The main difference is that the mats pictured have a Range Rover logo on them, facing the door. EAH500280PVA is the jet version of what I expect is the non-premium but still LR genuine mats, in the 2011 brochure. It goes on to say "2007 -2010 MY vehicles only". One does not see the whole mat so I don't know if these ones had a RR logo. The leather border on the 2005 brochure premium mat is wider than the one in your picture and the pile on the mat looks higher quality. The 2011 brochure pictures are so small that it is hard to form a view, and because the leather edging on the premium mat is a contrast colour in the brochure it might look wider. It's not as wide as on the 2005 premium mat. The pile shown on the 2011 brochure mats looks finer than that in your picture.
Andygriff73 Member Since: 29 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
I have the luxury ones with rubber backing and the Range Rover emblem.
