Home > Technical (L322) > Oil Flush before changing.
Bluegreygreen Rangie 2
Australia
Also Chris (encase you did not know... didnt see it mentioned) be sure to remove both sump drain plugs when doing the oil change
Dave 2010 3.6TDV8 Autobiography
D4 Bullbar, Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 255/60/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #588263 21st Mar 2021 4:17pm
Naki
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I bought my first TDV8 last week. I have just done an oil change on it. I found this feature very useful. Thanks for the info.
It’s the first time I have seen two drain plugs on a sump. Bizarre. The rear drain only let out a very small amount of oil, as I did it second after draining the forward plug. What’s the point of the rear drain plug?
I too am always perplexed on why TD engines manage to turn their oil black almost immediately. No matter what. I come from a Petrol engine background, where oil stays clean for a long while and gradual darkens. But I have two diesel land rovers now, so it’s getting used to it. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
2003 L322 TD6 Vogue with Facelift conversion
2000 Discovery 2 TD5 ES. Daily
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #661345 8th Apr 2023 12:21pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Separate oil pan from turbos. To ensure oil drain from turbos in offroad conditions when car inclination is too big and regular pan oil level can be above the level of turbocharger.
Post #661527 10th Apr 2023 6:45pm
Naki
Great reply thanks. Very good information. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #661537 10th Apr 2023 7:54pm
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
For the sake of a couple of quid on engine flush is it worth it??
Post #661917 14th Apr 2023 8:19pm
JayGee
Not worth it. Change the oil more regularly if you are worried about contamination or sludge. 2012 TDV8 Vogue (L322)
Post #661936 15th Apr 2023 6:04am
Naki
Look at the discussion on page one. The answer to this question is covered in depth. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #661983 15th Apr 2023 9:12pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Regarding Engine flushes, below is a video from O Reillys mobile mechanic. He did an experiment where he did an oil change on a land rover and when he dipped the oil after it was still black. He then drained that new oil and it was black. Believe it or not but it took 5 oil changes before he started seeing gold colour.
So as oil flushes go with the current price that would be over €600 and oil change!
?feature=shared
Worth a watch Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #681762 3rd Jan 2024 9:52am
jaguar3
Yes, thats true. I also tryed once, make 3 x oil change, it goes golder, but not compleatly.
https://www.fullfatrr.com/forum/topic64906.html?highlight=mine
Post #681764 3rd Jan 2024 10:32am
