Home > Maintenance & Mods (L322) > Td6 thermostat Renault 5 mod |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 |
Great minds think alike - I asked the very same question a few days ago in this thread: https://www.fullfatrr.com/forum/topic50700.html (scroll about half-way down the page to the latest messages).
24th Nov 2020 6:44pm |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 |
If you could take some pictures that would offer any help that would be great 👍 |
24th Nov 2020 7:22pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Just curious, how do you fix the Renault thermostat in place? Jubilee clip over the outside of the hose? |
24th Nov 2020 8:05pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 223 |
Jubilee clip over hose as per renault. |
24th Nov 2020 8:27pm |
The thermostat used is more of a short tube shape than the usual flying saucer shape, so it can't 'tip over' in the hose so to speak. Just need something to stop water pressure pushing it further up the hose, and a jubilee clip is used as kds2 stated. Although it seems likely that it's such a tight fit in the hose it isn't going to go anywhere anyway ... |
24th Nov 2020 8:44pm |
Thanks.
24th Nov 2020 8:54pm |
How does this work if the engine thermostat is goosed |
25th Nov 2020 6:28am |
The engine thermostat is goosed because it is stuck fully open allowing full coolant flow thereby not allowing the engine to heat up correctly. Using a separate thermostat allows the engine to heat as normal. |
25th Nov 2020 8:07am |
Ah I see so with this mod the new thermostat is closed then the engine warms up? |
25th Nov 2020 8:18am |
That's it. The supplementary thermostat simply replaces the function of the faulty engine thermostat. |
25th Nov 2020 8:26am |
Or to refine the answer slightly, the main thermostat opens at too low a temperature, which lets coolant through the radiator which overcools the engine. A second thermostat is placed in the engine end of the top radiator hose such that, even though the main thermostat has opened, coolant can't pass through the radiator until the coolant in the engine block reaches ~88°C and the second thermostat opens. |
25th Nov 2020 11:47am |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Try this:
25th Nov 2020 12:00pm |
I've just clamped my top radiator hose flat between two small bits of wood to test what happens on a quick trip round the local roads - gauge rises to 12 o'clock and stays there. Remove clamp and gauge returns to normal position of about 10:30. Engine warmed up surprisingly quickly with the clamp on, compared to what I'm used to.
27th Nov 2020 5:52pm |
New hose fitted and temperature gauge now sitting nicely at 12 o'clock. Only been round local roads at the moment, need to check it on a longer run.
28th Nov 2020 5:35pm |
