Home > Technical (L405) > Deployable two bar electrical socket fault
Flyingscotsman1
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Hi all has anyone ever had to free off the electrical socket on a deployable two bar on a Autobiography mine will not move
Post #586084 3rd Mar 2021 6:18pm
Yep, they seize when not used/maintained... If you can get it to start moving then you maybe able to rescue it? If not then they are available from JLR Thumbs Up
Post #586148 4th Mar 2021 12:52am
Flyingscotsman1
Cheers mate will do if i cannot get it to move will take it to the R R specialist i use has the bumper got to come of to get at it to try and free it
Post #586217 4th Mar 2021 12:35pm
No no, once the tow bar is deployed there is plenty of room even if it needs replacing sir... 👍
Post #586234 4th Mar 2021 2:35pm
Flyingscotsman1
Cheers Craig much appreciated these sites are great i use these and club sites to get help with my old bikes and caravan always most helpful thank you
Post #586287 4th Mar 2021 6:45pm
Flyingscotsman1
Hi Craig , Range Rover went into the specialists Land Rover garage I use today got lucky and with a bit of heat the electrical socket worked a treat even the cover over the terminals was seized but all now works a treat now thanks for your help.
Post #589900 1st Apr 2021 7:29pm
Thumbs Up Thumbs Up Thumbs Up
Post #589922 1st Apr 2021 9:57pm
