![]() | Home > Technical (L405) > Deployable two bar electrical socket fault |
Yep, they seize when not used/maintained... If you can get it to start moving then you maybe able to rescue it? If not then they are available from JLR |
Flyingscotsman1 Member Since: 02 Mar 2021 Location: buckinghamshire Posts: 26 ![]() ![]() ![]() |
Cheers mate will do if i cannot get it to move will take it to the R R specialist i use has the bumper got to come of to get at it to try and free it |
No no, once the tow bar is deployed there is plenty of room even if it needs replacing sir... 👍 |
Cheers Craig much appreciated these sites are great i use these and club sites to get help with my old bikes and caravan always most helpful thank you |
Hi Craig , Range Rover went into the specialists Land Rover garage I use today got lucky and with a bit of heat the electrical socket worked a treat even the cover over the terminals was seized but all now works a treat now thanks for your help. |
