Home > Technical (L405) > Bonnet not sitting flush
Bmax01
The driver side bonnet isn’t sitting flush, passenger side seems fine. Maybe I’m not pushing down hard enough on the bonnet to close it. Or there’s an issue with the latch? Anyone had similar issues? Pictures below.
Ta,
 L405 4.4 AB Loire Blue
Tesla Model Y
Audi A6 2012 (sold)
BMW 5 series 3.0 petrol, champagne II edition (sold)
Post #586012 3rd Mar 2021 12:13am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
It has two latches. Probably the left one didn't engage, push a little harder on that side...
Post #586016 3rd Mar 2021 6:12am
jackcramerr
Slam it hard. Do not push it.
I have seen this issue on the l405. Didn't notice it until a friend pointed it out that bonnet is not closed.
Post #586026 3rd Mar 2021 9:50am
Do you own a screwdriver sir? Open the bonnet and push a screwdriver into the latch as if it was the bonnet closing, this will show you if the latch is at fault? DONT FORGET to pull the bonnet pull once finished... Whistle
Be very careful pushing the bonnet down when closing as they are only Aluminium and will dent VERY easily sir...
As mentioned above, slam it (once you have checked the latch is working)... Thumbs Up
Post #586027 3rd Mar 2021 9:57am
Bmax01
Cheers folks, much appreciated! I'll give this a go later on today. L405 4.4 AB Loire Blue
Tesla Model Y
Audi A6 2012 (sold)
Post #586029 3rd Mar 2021 10:38am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Had this before as well - I fixed it by adjusting the position of the latch on that side. Remove the grill and you'll see the bonnet catches - just need to loosen and slightly move it until the bonnet catches properly Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #586058 3rd Mar 2021 3:39pm
knwatkins
I had this problem with my L405. The latches needed a good soaking in WD40. I also found that the gaps between the edge of the bonnet and the doors needed adjusting and this is done via the nuts in the back corners of bonnet, on the hinges. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #586073 3rd Mar 2021 6:02pm
Bmax01
Thanks again for all your help. Looks like all it needed was reasonably hard slam and it was fine (after Craig’s suggested check on the latch, thanks buddy may visit your garage on the way to my mums in Wales for a gear service at some point).
Anyhow, difficult to know when to be gentle and when to be a little rough with these things! L405 4.4 AB Loire Blue
Tesla Model Y
Audi A6 2012 (sold)
Post #586630 7th Mar 2021 6:48pm
