The link posted above by Stan concerns the L320 Range Rover Sport and not the L405.
On the L405, the actuator/valve block is on the left hand side of the vehicle.
Firstly, you need to remove the rocker panel plastic cover...
![](https://www.fullfatrr.com/gallery/albums/userpics/22607/1.JPG) | Click image to enlarge |
Then you will see the valve block...
![](https://www.fullfatrr.com/gallery/albums/userpics/22607/2.JPG) | Click image to enlarge |
The module that controls the actuator is mounted next to the accelerator pedal on RHD vehicles. I'm not sure if it's in the same position on LHD vehicles. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
