Home > Technical (L405) > Dynamic response actuator
funnyguy1
United States
Can someone tell me where the DRA is located on the L405? Thx!!
Post #585747 1st Mar 2021 2:26am
any good?
https://static.nhtsa.gov/odi/tsbs/2014/MC-10101861-9340.pdf ... - .- -.
Post #585789 1st Mar 2021 1:34pm
funnyguy1
United States
Thanks Stan!!
Post #585848 1st Mar 2021 8:09pm
knwatkins
The link posted above by Stan concerns the L320 Range Rover Sport and not the L405.
On the L405, the actuator/valve block is on the left hand side of the vehicle.
Firstly, you need to remove the rocker panel plastic cover...
Then you will see the valve block...
The module that controls the actuator is mounted next to the accelerator pedal on RHD vehicles. I'm not sure if it's in the same position on LHD vehicles. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #585855 1st Mar 2021 9:20pm
