![]() | Home > Technical (L322) > Turbo Actuator, Turbo boost control solenoid |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
hey model and engine would be good so we can help 2012 Vogue 4.4 TDV8 - Current
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
And perhaps a lot more on the background as to why would help, which all are happy to do. |
Ikorodu Member Since: 19 Feb 2021 Location: Kent Posts: 5 ![]() ![]() ![]() |
Oops!!
I'll happily go down in flames!!!!
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2655 ![]() ![]() |
Was just the belt changed or were the pulleys also changed? Initial squeaking or squealing suggests dry pulley bearings.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
There is no chassis to lift the body off unless you have a Sport [think I'm correct?].
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
http://www.fullfatrr.com/gallery/albums/us..._TOPIx.pdf
Thanks for the help/tips Guys
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Are you in restricted performance?
Lubricant isn't applied to the pulleys which use a so-called sealed bearing. |
@GGDR thanks, will check them all and share my findings
Be ready to spray water onto the belt to see if the noise stops. If it stops then the belt is very likely the culprit. |
Another way to prove or eliminate 'belt squeal' is do what my Indy did........dived into his tool box and came out with a container of...........Johnsons Baby powder! [other similar makes are available]. He squirted this on the belt, fired her up & quietness. You can always buy expensive 'anti squeal' spray but this stuff absorbs any moisture [cause of the squeal] and after cleaning off any powder, all sorted! |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I bet it smelt nice too |
