![]() | Home > Technical (L322) > Another Air Suspension Help Thread |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8499 ![]() ![]() ![]() |
Try a hard reset,
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 ![]() ![]() ![]() |
When you say you don't have codes, do you mean no EAS codes? Or no codes completely?
Beg to differ, EAS needs steering angle and will be inhibited until the steering wheel is run lock to lock after battery off, not sure why it would want you to do that if it doesn't care about alignment and thus wheel angle. I assume OP has diagnosed alignment by looking at the wheel and not by having it on a tracking machine but taking it off without having adjusted it. |
Yeah, my bad, was thinking the tracking would be out a bit, but a non centered steering wheel isn't good... |
noquarter1 Member Since: 07 Feb 2021 Location: Utah Posts: 3 ![]() ![]() |
Update: tried a hard reset, then the steering wheel lock to lock. Unfortunately, didn't resolve the problem. I did notice the battery was around 11.5v at rest, so I'll replace the battery.
"they said they don't have the tools to align a Land Rover"
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 298 ![]() ![]() ![]() |
Not sure if they are the same as a D3 but you need to put the suspension in tight tolerance mode to do a wheel alignment. Which could be why they did not do it.
I found that out just after I had it done on my old one, put it in tight tolerance and returned to find it was exactly the same..!!
It's been a while, but I wanted to pop in to provide updates. Unfortunately, I still have the error message and I still can't control the air suspension using the interior controls, only through the diagnostic tool.
What diagnostic tool are you using and what fault codes is it saying..? Pete
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
@noquarter1 did you resolve this ?
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
Mine did this, turned out to be the steering angle sensor, pig of a job to change but worked. I dont think at the time it was throwing any specific codes up. Just alot of lights and the inability to control the air suspension. |
