Home > In Car Electronics (L322) > Digital tv in 03
noddy5vogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Digital tv in 03
Hi fitted hybrid tv module some months back to my 03 ff and dont really get a decent picture living in Blackpool wondered if it is possible to boost signal or fit different stronger aerials to obtain better pic
Post #62777 5th May 2011 7:01pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I'm guessing you plugged the antenna in ok. What is the signal like generally in Blackpool?
Assuming you have replaced an analogue unit with 2x antenna You could try something like this which has the correct connector.. sma.. although you would need 2.. one on each rear window to duplicate the standard car setup.
http://cgi.ebay.co.uk/ES098-In-Car-DVB-T-D...2a103acbba
I've just bought a Digital TV Unit for the Pathfinder though I won't know how good or not reception is for a while as the DVD / Monitor I git had to be sent back for replacement Rolling Eyes 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #62924 7th May 2011 12:54am
