I'm guessing you plugged the antenna in ok. What is the signal like generally in Blackpool?
Assuming you have replaced an analogue unit with 2x antenna You could try something like this which has the correct connector.. sma.. although you would need 2.. one on each rear window to duplicate the standard car setup.
http://cgi.ebay.co.uk/ES098-In-Car-DVB-T-D...2a103acbba
I've just bought a Digital TV Unit for the Pathfinder though I won't know how good or not reception is for a while as the DVD / Monitor I git had to be sent back for replacement 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
