![]() | Home > Technical (L405) > Remote heat / timed climate |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Can you hear the fuel burner start and then continue to run ? Did you give the button a long press and did it flash green for approx 15 secs before extinguishing ?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
It might need activating as per this thread.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Does your hazard warning lamp switch illuminate and your "auto" climate button start to flash some 5-10 seconds after you press your remote? Because that's how mine works...
Gazm007 Member Since: 22 May 2019 Location: Surrey Posts: 37 ![]() ![]() ![]() |
thanks Chaps.
not sure why i would need to activate it as its already fitted as factory standard but i'll have a look at what happens inside when i press the button on the fob! cheers |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
There are a few things that will stop the heater working, low battery or low fuel being two of them, also note the heater can only be used once between engine starts.
