Home > Technical (L405) > Remote heat / timed climate
Gazm007
United Kingdom 2013 Range Rover Autobiography SDV8 Havana
Hi all
I have this fitted to my car and have the remote. Over the last few days I’ve tried using the remote (flashed green on fob) but did not do anything and also the timed climate from the menu in the car. Neither has worked. The car had been driving durning the last few days so don’t think it was due to a low battery. Anyone got any suggestions.
Thanks
Post #583039 9th Feb 2021 10:30pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Can you hear the fuel burner start and then continue to run ? Did you give the button a long press and did it flash green for approx 15 secs before extinguishing ?
Do you have over a quarter of a tank of fuel ? I am not sure what level it cuts out but if low on fuel the remote heater will not start. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #583055 10th Feb 2021 7:31am
Weegie
It might need activating as per this thread.
https://www.fullfatrr.com/forum/topic49512...=reset+fbh John
GAP iiD BT
Post #583095 10th Feb 2021 10:54am
Does your hazard warning lamp switch illuminate and your "auto" climate button start to flash some 5-10 seconds after you press your remote? Because that's how mine works...
The 405 uses a different type of heater to a 322, i think its called an eberspacher?
Post #583101 10th Feb 2021 12:21pm
Gazm007
thanks Chaps.
ive never actually stood beside it when trying - will try that tomorrow and see what hapoens
Cheers
Post #583189 10th Feb 2021 10:23pm
Gazm007
not sure why i would need to activate it as its already fitted as factory standard but i'll have a look at what happens inside when i press the button on the fob! cheers
Post #583190 10th Feb 2021 10:27pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
There are a few things that will stop the heater working, low battery or low fuel being two of them, also note the heater can only be used once between engine starts.
The flashing of the led in the fob indicates the message is received by the vehicle, so there is a fault which is stopping the FFBH firing up
Ideally you need to get the fault codes read which should indicate where to look.
Post #583326 12th Feb 2021 7:16am
