Home > Maintenance & Mods (L322) > Correct Alternator TDV8 4.4 2011
Sonearly
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Advice please
Just received exchange alternator and required confirmation
The alternator from the car had the following indentification
BH 41 10300 AC
104210-6280
The replacement
BH 41 10300 AD
104210-6281
I am told they are the same LR code LR022528. And the later a replacement.
Is the replacement OK to use
Post #582822 8th Feb 2021 3:27pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
If I had to guess I would assume the AC to AD is merely a revision update.
Since the rest of the number is the same, I would not be concerned about fitting it, if all connections are the same. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #583069 10th Feb 2021 9:58am
Sonearly
Found the answer after a lot of research.
For anyone that needs to know
The correct Denso part number for TDV8 engines is
DAN1110
There are lots of different LR numbers but ultimately if it’s for a TDV8 whatever model DAN1110
Post #583180 10th Feb 2021 10:06pm
