Home > Maintenance & Mods (L405) > Battery problems
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
Battery problems
My 13 4.4 autobiography keeps flagging up battery low start engine. I have changed both batteries not cured. Checking alternator charge 13.5.
any ideas or advice gratefully received 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #582272 3rd Feb 2021 7:12pm
have you 'told' the FF that it has a new battery via a diagnostic unit like the GAP iidtool.. ... - .- -.
Post #582274 3rd Feb 2021 7:14pm
Watty
No i have not i will give that a try in the moorning 07 Vogue SE Java Black 3.6 TDV8
Post #582275 3rd Feb 2021 7:17pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Is there a way to do this without an iid tool? 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #582278 3rd Feb 2021 7:33pm
Watty
updated FF just now took it a run still says battery low 😂😂😂 07 Vogue SE Java Black 3.6 TDV8
Post #582283 3rd Feb 2021 8:17pm
i have had a forum search and some say that the low battery message goes away after a few days , others mention a dashcam could be draining he battery..
not fitting the correct type of battery or a faulty battery management system {BMS] are other suggestions... ... - .- -.
Post #582287 3rd Feb 2021 9:16pm
What batteries have you fitted? When running, you say its 13.5v? Is this running without any vehicle electrics switched on? Like heated screens, blowers, lights & seats etc... With that little lot on, she should still achieve 14-14.4v sir...
Post #582305 4th Feb 2021 1:14am
Good username for someone with battery problems.
Post #582319 4th Feb 2021 8:58am
Take the batteries back to be tested ?
If they are OK, sounds like maybe an alternator fault ?
Post #582328 4th Feb 2021 10:04am
Chalky
Do you have a Blackvue Dashcam running in Parking mode? All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #582341 4th Feb 2021 12:01pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
subbed. I've been getting low battery start vehicle errors when I shut off the car/enter. Seems to start when the temp gets very cold (below freezing). Debating getting a new battery....but interested to see if something else fixes your issue.
Vehicle starts up no problem every time. Interior lights won't light up when opening the door etc (i guess the brain tells it to do this b/c of the error). I see a replacement battery plus reg being a simple yet costly repair (for what it is) at the dealer. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #582485 5th Feb 2021 2:11pm
Watty
Brand new RR batteries fitted, dont get near 14.00 will try alternator next Thank you 07 Vogue SE Java Black 3.6 TDV8
Post #582509 5th Feb 2021 5:21pm
Get the batteries tested first - even a new one can be faulty
Post #582523 5th Feb 2021 8:32pm
as above..and check the connections... ... - .- -.
Post #582526 5th Feb 2021 9:08pm
horse86
so you went to dealer for OEM LR replacement? I'm on the look for what the OEM equivalent options are 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #582963 9th Feb 2021 3:41pm
