Home > Maintenance & Mods (L405) > Battery problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
have you 'told' the FF that it has a new battery via a diagnostic unit like the GAP iidtool.. ... - .- -.
3rd Feb 2021 6:14pm |
Watty Member Since: 02 Oct 2013 Location: Kirkintilloch Posts: 56 |
No i have not i will give that a try in the moorning 07 Vogue SE Java Black 3.6 TDV8
3rd Feb 2021 6:17pm |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 |
Is there a way to do this without an iid tool? 2013 Range Rover Autobiography 4.4 SDV8
3rd Feb 2021 6:33pm |
updated FF just now took it a run still says battery low 😂😂😂 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
3rd Feb 2021 7:17pm |
i have had a forum search and some say that the low battery message goes away after a few days , others mention a dashcam could be draining he battery..
3rd Feb 2021 8:16pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
What batteries have you fitted? When running, you say its 13.5v? Is this running without any vehicle electrics switched on? Like heated screens, blowers, lights & seats etc... With that little lot on, she should still achieve 14-14.4v sir... |
4th Feb 2021 12:14am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Good username for someone with battery problems. |
4th Feb 2021 7:58am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Take the batteries back to be tested ?
4th Feb 2021 9:04am |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 903 |
Do you have a Blackvue Dashcam running in Parking mode? All LR cars from 1984
4th Feb 2021 11:01am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
subbed. I've been getting low battery start vehicle errors when I shut off the car/enter. Seems to start when the temp gets very cold (below freezing). Debating getting a new battery....but interested to see if something else fixes your issue.
5th Feb 2021 1:11pm |
Brand new RR batteries fitted, dont get near 14.00 will try alternator next Thank you 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
5th Feb 2021 4:21pm |
Get the batteries tested first - even a new one can be faulty |
5th Feb 2021 7:32pm |
as above..and check the connections... ... - .- -.
5th Feb 2021 8:08pm |
so you went to dealer for OEM LR replacement? I'm on the look for what the OEM equivalent options are 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
9th Feb 2021 2:41pm |
