![]() | Home > Wheels & Tyres > Discovery 4 fit L322 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2599 ![]() ![]() |
I had that style of D4 19" rims fitted to my MY12 4.4 TDV8 which has the 6-pot Range Rover labelled Brembos. |
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 ![]() ![]() ![]() |
Thanks!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
They should just bolt straight on.
Haven’t got round to going to see these yet as I got called away to work for 3 weeks.
As Graeme says above they will go over 6 pot so 4 pots shouldn’t prove a problem. Quite a few 19” will go over the 4 pots on the sc and 3.6tdv8. The disco callipers are quite chunky, and actually the 19” l332 4.4tdv8 wheels which fit over the 6 pots on the 322 won’t go over the D4 standard callipers, so visa versa the D4 wheels should clear absolutely perfectly on a 322. There is nothing that can't be fixed with a hammer😜😜
Thanks for clearing this up folks.
That applies to the 2010-> 5.0 or 4.4 tdv8👍🏻 There is nothing that can't be fixed with a hammer😜😜
Thanks folks,
