Home > Wheels & Tyres > Discovery 4 fit L322
Dode4444
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Hi all,
Still relatively new to RR ownership so trying to find out if these wheels off of a discovery 4 will fit my 4.2 Supercharged L322. As far as I am aware the SC callipers can stop some wheel figments.
Wheels came off a discovery 4 with 255/55/19 tyres.
Thanks .
 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #582060 1st Feb 2021 8:25pm
GraemeS
Australia
I had that style of D4 19" rims fitted to my MY12 4.4 TDV8 which has the 6-pot Range Rover labelled Brembos.
Post #582061 1st Feb 2021 8:40pm
Dode4444
Thanks!
So it sounds promising that they’ll fit.
Just to confirm.... I shouldn’t need different wheel nuts if the wheels were from a discovery 4 is this correct? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #582063 1st Feb 2021 8:46pm
They should just bolt straight on.
Looking for some of them for my D4 at the moment! There is nothing that can't be fixed with a hammer😜😜
Post #583729 14th Feb 2021 9:15pm
Dode4444
Haven’t got round to going to see these yet as I got called away to work for 3 weeks.
Will they definitely go over my brembo supercharged size calipers? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #583733 14th Feb 2021 9:21pm
As Graeme says above they will go over 6 pot so 4 pots shouldn’t prove a problem. Quite a few 19” will go over the 4 pots on the sc and 3.6tdv8. The disco callipers are quite chunky, and actually the 19” l332 4.4tdv8 wheels which fit over the 6 pots on the 322 won’t go over the D4 standard callipers, so visa versa the D4 wheels should clear absolutely perfectly on a 322. There is nothing that can't be fixed with a hammer😜😜
Post #583747 14th Feb 2021 10:15pm
Dode4444
Thanks for clearing this up folks.
I had read so many posts lately that state only 20’s can be used on the SC models or only certain 19’s but never any specific ones. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #583751 14th Feb 2021 10:33pm
That applies to the 2010-> 5.0 or 4.4 tdv8👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #583753 14th Feb 2021 10:47pm
Dode4444
Thanks folks,
Hopefully this gives me more choice and options for some AT tyre option a then 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #583756 14th Feb 2021 10:54pm
