Home > Technical (L322) > Pulley squeak - AJV8 4.2 SC 2006 - Pulley Bearing Specs Plz!
andyt109
All, I have a squeak, pretty sure its a pulley. It had a new alternator recently so ill rule that out. No noises once warm, only on cold start.
Before I shell out £170 on pulleys with tensioners attached just for the bearings, seeing if anyone knows the bearing details for these parts for the AJV8 4.2 SC (2006) - Of course I can take it all apart, check the bearings and then put it back together, but to save doing that twice its worth posting on here!
List of parts available on Island 4x4:
Drive Belt Tensioner 4.2/4.4 AJV8 (SKF) PQG500030 *Primary* - 6B209A on diagram
Drive Belt Upper Tensioner L322 4.2/4.4 AJV8 (Genuine) PQR500140 *Primary* - 19A216B on diagram
Drive Belt Lower Tensioner L322 4.2/4.4 AJV8 (Genuine) PQR500130 PQR500350 *Primary* - 19A216A on diagram
Drive Belt Tensioner 4.2/4.4 AJV8 (Genuine) LHP500100 LHP500110 *Secondary* - 6B209B on diagram
Diagram from useful Russian website:
https://lrparts.ru/katalog/rover-2002/4-2-...rcharged-2
Other Spinning parts it could be short of the water pump or other ancillaries:
8632A - PQS500490 – fan pulley – https://www.island-4x4.co.uk/viscous-mount...38065.html
Cheers.
Post #581252 26th Jan 2021 3:27pm
Parallel
Hi Andy. Have you checked it's not the belt? I had the exact same symptoms in the past, squeaked for 2-3mins when cold but then was fine. A new belt cured mine, and I was certain it was a pulley as it didn't sound like a typical belt squeak.
Try a small squirt of water on the belt and see if it quietens down. Could save you some work/cash if it is the belt, nothing to lose trying it.
Post #581255 26th Jan 2021 3:39pm
andyt109
Good shout, I'll give that a try. They look in reasonable condition, no obvious perishing or cracking etc, but no idea on age, only had the car a month or so may just be old.
Cheers
Post #581258 26th Jan 2021 3:45pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
if the water trick shows its not the belt then check this post
https://www.fullfatrr.com/forum/topic57991.html Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #581260 26th Jan 2021 3:48pm
andyt109
Thanks for the link! This is a great community.
For any future readers the bearings for both tensioners and both idlers spec is: 6203-2RSH
https://www.bearing-king.co.uk/bearing/620...x12mm/4225
Apparently can be done with a vice as per above link.
Viscous fan bearing currently unknown but heres the link for the whole part:
Cheers all
Post #581266 26th Jan 2021 4:22pm
dhallworth
It was me who replaced the bearings, a very easy job and a very cheap job that can be done with nothing other then some sockets and a vice Smile
Post #581550 28th Jan 2021 9:21pm
andyt109
David,
Appreciate your info on the other thread, very helpful.
Bearing king were excellent, less than 24 hours between ordering and delivery.
Just waiting on the belts from island 4x4 then I'll give it a go!
Cheers
Post #581555 28th Jan 2021 9:37pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Re the squeak:
There’s a modification/ upgrade to one of the pulley’s where it was originally a flat pulley and it allowed the belt, at startup, to effectively slide around and squeak. The updated pulley is v-shaped. Once I changed mine, the squeak went away and I didn’t change any other bearings. I’ll look for a link.
Regards
John
Post #581598 29th Jan 2021 11:09am
andyt109
That sounds useful! I'll have a look for that too, let me know if you find it in the meantime.
I now have the rest of the parts in my possession, so will post details of the viscous bearing once I've measured it etc.
Post #581664 29th Jan 2021 6:50pm
tb10
I think the part number is PQR500350. The original pulley was totally flat and open, the new one v-shaped so higher sides; NOT v-grooves actually in the pulley. The diagram isn’t clear but there’s a greyed part number of PQR500350.
I’m in isolation atm so I can’t check but it appears to be the culprit.
Hope this helps?
Post #581668 29th Jan 2021 7:10pm
andyt109
Sorry to hear your in isolation - hope all is well.
So that part number PQR500350 applies to 19A216A on the diagram in my first post which I think is just a diagram reference.
This one looks like it has the sides in the image:
https://www.island-4x4.co.uk/drive-belt-lo...37066.html
Google images also mainly shows ones with sides
I'll have a look what's on the car tomorrow if the weather holds up.
Cheers
Post #581677 29th Jan 2021 8:33pm
