Home > Technical (L322) > Pulley squeak - AJV8 4.2 SC 2006 - Pulley Bearing Specs Plz! |
andyt109 Member Since: 23 Nov 2020 Location: London Posts: 29 |
All, I have a squeak, pretty sure its a pulley. It had a new alternator recently so ill rule that out. No noises once warm, only on cold start.
26th Jan 2021 3:27pm |
Good shout, I'll give that a try. They look in reasonable condition, no obvious perishing or cracking etc, but no idea on age, only had the car a month or so may just be old.
26th Jan 2021 3:45pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 565 |
if the water trick shows its not the belt then check this post
26th Jan 2021 3:48pm |
Thanks for the link! This is a great community.
26th Jan 2021 4:22pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3059 |
It was me who replaced the bearings, a very easy job and a very cheap job that can be done with nothing other then some sockets and a vice
28th Jan 2021 9:21pm |
David,
28th Jan 2021 9:37pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 336 |
Re the squeak:
29th Jan 2021 11:09am |
That sounds useful! I'll have a look for that too, let me know if you find it in the meantime.
29th Jan 2021 6:50pm |
I think the part number is PQR500350. The original pulley was totally flat and open, the new one v-shaped so higher sides; NOT v-grooves actually in the pulley. The diagram isn’t clear but there’s a greyed part number of PQR500350.
29th Jan 2021 7:10pm |
Sorry to hear your in isolation - hope all is well.
29th Jan 2021 8:33pm |
