Home > Maintenance & Mods (L322) > Frozen door mechanism
Jayk69
Any one else had a door freeze?
my drivers door opened today -6 was the temp but then i could not close it the door simply would not latch. checked the latch it moved ok so i held the door shut and locked the car the door locked but now will not open from inside or out!!
I think the links have frozen, i climbed in through the passenger seat and the internal door handle now feels like it is trying to move to open (As opposed to just moving with no friction).
I will wait to see what happens as the temp gets above freezing today to see if it goes back to normal.
Any advise to prevent this in the future would be gratefully received. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #581036 25th Jan 2021 10:46am
Rosco
Common issue, various threads on the forum, however for me a kettle of 'not quite boiling' water frees it up Thumbs Up
Post #581038 25th Jan 2021 10:51am
Spray graphite helps, sprayed into mechanism at service point... Gummi Pflege or simple vasalene on the door rubbers helps them not stick shut...
I left SWMBO’d a note on the kettle late last night reminding her “frozen door handles” for this morning’s school run... Before my 12yr old rips the rear door handle off her Disco!!!
Post #581045 25th Jan 2021 11:15am
there has been a lot of moisture in the air so many have had the frozen door problem and its not just FF's suffering...
as said by Rosco, warm water round the door frame helps free them.. ... - .- -.
Post #581047 25th Jan 2021 11:16am
V8 Bob
Had the same issue two weeks ago mine freed after having the heater in for ten minutes. The drivers window was also stuck wouldn’t move even with a hand on either side of glass. A night in the garage cured that in lieu of hotter weather 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #581053 25th Jan 2021 11:25am
Jayk69
thanks for the replies.
my window always stuggles with sub zero temps
i have added silicone to the door rubbers.
i think my issues are the cables that operate the mechanism are maybe warn and stretched a bit and have then frozen. so neither handle operates the mechanism. same thing happens on my mountain bike gears in the winter. 2012 Vogue 4.4 TDV8 - Current
Post #581060 25th Jan 2021 11:48am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
LOL I had the same thing this morning. A right pain in the backside. Was able to open first thing but then not close. Once I was able to close I couldn’t open it again grrrr
Never had this on any other car. But thanks for the tips. Will prepare it for tomorrow morning 🤣
Post #581076 25th Jan 2021 1:17pm
GGDR
exactly same for me this morning
minus 1°
door popped open (but second latch caught it) as I turned left
Shocked Cheers, Greg
Post #581080 25th Jan 2021 1:25pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Same as me this morning. Kettle 3/4 the way to boiling, pour it over the metal key if your on the older key ignition range, pop that into the key lock and leave it for 30 seconds, open door, pull door n push door button down. Should do the job well did frr me
Post #581083 25th Jan 2021 1:35pm
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Just had a can of WD40 Silicone Lubricant delivered, sprayed locks and door rubbers for preventative maintenance as have been victim to this very same thing in the past. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #581087 25th Jan 2021 2:17pm
bishbosh10
Sheesh! How technology has moved backwards!
My 1992 RRC had heated door locks - you just held the handle out (remember the old Morris Marina parts bin ones!) and the lock defrosted! Was fantastic in the middle of Canadian Winters. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #581089 25th Jan 2021 2:25pm
Strider
Yup,
Went out this morning to the fatty everything frozen solid, operated the central locking,all the buttons popped up, went
to open the drivers door, it opened about 15mm then "clonk" no more movement.
Poured almost boiling water on lock and handle, still no movement, pushed it shut and locked it.
2pm went out and tried it again "success". What a c***p design weakness
Its weird, even though it can be a pain in the a**** at times still think they are the greatest Thumbs Up .
Post #581139 25th Jan 2021 8:36pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Although I had the locks and latches sprayed with WD40 regularly, I neglected to silicone spray the door seals (I use Würth). So at -5 C they froze and doors wouldn't open.
I've NEVER sprayed the Freelander but it has never given me any trouble in a freezing morning...go figure Rolling Eyes
Post #581143 25th Jan 2021 9:06pm
procee
My door latch regularly freezes overnight - I can open the door but it will just bounce open when I try to shut it. My two fixes so far have involved an extension lead and my wife's hair dryer, or an extension lead and a fan heater to thaw it out. 2006 MY FFRR 4.2 S/C autobiography (Auckland Blue - 901)
1996 Discovery 300Tdi S (death by rusting) (Silver)
1995 Volvo 850 T-5 est (now in Valhalla) (verdigris metallic)
1987 Volvo 240 GL est (now in Valhalla - not owned but driven lots)
1990 Kawasaki ZZR600 Blue
1979 Honda CB250 NA Superdream Red
Post #581190 26th Jan 2021 10:47am
take the door latch mechanism out and pack it full of grease...this will stop it freezing up.. ... - .- -.
Post #581194 26th Jan 2021 11:04am
