Home > Technical (L322) > 2011 re-sync key following key battery replacement
19UNK
Hi all
I have searched for quite some time and failed to find what I thought would be very easy, but no!
I've replaced the battery in one of my keys, no problem, but I cannot get it to now work. I have found the instructions for syncing the key on an older model with a traditional ignition barrel but as mine is 'keyless' I cannot anywhere find the process of how to sort it. I presume I can do it myself as opposed to require a professional!?
I also don't have a manual (have ordered one today) so have no reference. Can someone please advise me what to do in the case of a 2011 model??
Thanks all
Post #581017 25th Jan 2021 1:59am
the owners and workshop manual are in the wiki... ... - .- -.
Post #581022 25th Jan 2021 6:20am
DrRob
Scroll to the bottom of the Wiki page for owners manual download
https://www.fullfatrr.com/wiki/Main_Page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581029 25th Jan 2021 9:04am
Baltic Blue
19 UNK,
The key automatically syncs with the car on 2010/12. models when you have changed the battery, but they are very fickle about working with some makes of replacement battery.
Duracell are a bit more expensive than some, but work every time.
Also be careful not to leave greasy fingerprints on the replacement by avoiding touching the faces and polishing it with a clean tissue.
Post #581039 25th Jan 2021 9:51am
mpirie
I found that locking and unlocking the car from the outside forces the key to resync and be recognised.
Mike
Post #581040 25th Jan 2021 10:05am
DrRob
Mike (in Scotland) - that's what I do and it works a treat.... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581091 25th Jan 2021 1:31pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Don't forget to place the key near the foot well light under the steering column.
Post #581095 25th Jan 2021 1:49pm
