![]() | Home > Maintenance & Mods (L322) > TDV8 P132E Turbo actuator - Seek help in Herts or N London |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
As far as i am aware the FF range is a tub so you cannot take the body off.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
What’s all this body off malarkey that folk get told |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
....and you CAN get to the N/S actuator arm to spray your lubricant of choice onto it, but you won't be able to see the top of the actual actuator arm, so you'll need a big straw and a good aim! |
kaoleary Member Since: 14 Sep 2013 Location: Hertfordshire Posts: 26 ![]() ![]() ![]() |
Thanks for your replies. For the sake of a roll around on the floor and a can of WD40, I'm going to have a go at it. |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
If your specialists thinks the body comes off the first thing is find another one |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
I agree this is exactly as I did it. WD40 do a can with a long flexi metal straw thing on it to free it off and then the same straw will fit onto a spray 3 in 1 can to lube it. Just remember everytime you are dropping the oil to spray the actuators 2010 3.6TDV8 Stornoway Grey/ Black interior - gone 2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone 1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone 1977 White - gone (should have kept) |
