![]() | Home > Technical (L322) > Deployable Steps (again, I know...) |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Hi when they are first fitted they require power to open them? check out the fitting instructions in WIKI? |
Hermes Member Since: 06 Nov 2020 Location: Oop north Posts: 108 ![]() ![]() ![]() |
Tinman, thanks but I might need to re-phrase my question:
I would have thought the same as you are thinking? that they should move freely as the motors open and close any resistance will put a load on the motors? |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 ![]() ![]() ![]() |
Hi there
Alex, I’m in the dark as much as you I’m afraid... at the moment, I’m just cleaning everything in sight but the hinges still seem stiff. Am hoping someone has a magic bullet to point me in the right direction. I haven’t tried the motors/gearboxes yet as there’s no point until I’ve cracke the hinge issues. If/when I get to the bottom of it, I’ll take some pics and post them.
It takes force and I figure its not a great idea. However the system allows you to do that as I have found out when changing a tire and I need to take the step off to fit the bottle jack. Kinda of a pain to do but in the process I can see the arms have movement. 2008 HSE B. Grey
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
When I was working on the set I had briefly, as an example, after lubricating the non powered brackets, they would both move very easily under their own weight.
Paul,
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
I've just replaced a broken bracket with a brand new one and can offer these observations which may help
I suspect that may be the case in Florida but I think that the salt on the roads in the UK might prevent that |
I used plenty of "3 in 1" oil on the moving pivots - obviously off the car to allow the steps to be orientated to maximise penetration of the oil.
Am in the process of freeing off the pivots.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
they are a sh....it design.
Roger,
