Home > Technical (L322) > 2012 Westminster Various Problems
Goodluck247
Hi All,
I have put around 300-400 miles on my recent purchase which is a very late 2012 Westminster. Mechanically, the vehicle breezes on the road, no rough idling or lumpy throttle. All the problems seem to be little electrical issues.
This is what I've discovered so far -
. Front courtesy lighting - The front courtesy lights don't work on opening the door or via the switches. The rear courtesy lights work fine and can be controlled via the light switch i the front. If one bulb goes can this take the rest of them out?
. Very intermittent heater blower. Leaving home this morning, the blower functioned as it should. Motor does sound a little loud though. By mid-day, blower completely unresponsive. I did read about it could be the final stage resistor? Or could this be the blower motor itself?
. Parking sensors are extremely intermittent as picked up on a previous post of mine.
. Oil level not available - Tried to check the oil level however the message displays unavailable. This was after around an hour and a half of driving and in a level car park.
Could there be anything that links these problems together or should i approach these all as independent issues? Any advice or assistance would be very much appreciated. Many thanks !
Post #579658 13th Jan 2021 9:18pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Trying holding in the front central light switch for several seconds..you can knock the interior lights off doing this.
FSR normally leaves fan switched in but may be the cause.
For oil level check need engine hot, parked level and to stand for about 20 minutes. Again I believe this can be read differently with bonnet open. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #579659 13th Jan 2021 9:23pm
DrRob
Oil level - check it cold and it should be a couple of notches below max. Then check it 30mins after switching off hot engine. Both times ignition on only remember Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579660 13th Jan 2021 9:26pm
DrRob
Heater.
Check fuse in boot first. It’s one labelled with a fan symbol. If ok then FSR next cheapest check
FSR - see https://www.fullfatrr.com/forum/topic58107.html from earlier today. Accessed from footwell. Try replacing that.
Also try lubricating the fan motor spindle via pollen box removed. Worth a try.
Full workshop manual is free to download in the Wiki. Do it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579662 13th Jan 2021 9:29pm
mjdronfield
Agree with the above. Holding the light switch in for a good few seconds will stop it coming on. Useful if leaving doors open etc. Press and hold again to return to normal operation. Worth a try.
The FSR is the cheapest and easiest place to start, and quite a common issue.
Wait for about 15 to 20 mins after turning engine off before you try and check the oil level. But not much longer.... or you will get the same message again. Failing that, I imagine you have a sensor issue.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #579663 13th Jan 2021 9:31pm
Courtesy lights are you talking door puddles or inside lights?
Oil level, It needs to stand and settle for about 20-30mins on a hot engine to get a reading. It will give the response you said if it isnt ready.
The heater blower sounds like the switch. If you put it on auto does it come on?
Have a look at the sensors, have they been blown over with paint?
They all sound like individual issues, don’t think there is anything in common there. There is nothing that can't be fixed with a hammer😜😜
Post #579664 13th Jan 2021 9:34pm
Baltic Blue
For the oil level....
Try the following.
Open the bonnet
Press start button to bring up display but DON’T start engine
Getup the oil level message even if it says Not Available
Double click the cruise control reset button
Oil level should now rest and level show.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #579665 13th Jan 2021 9:48pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
my 2010 definitely had an FSR and this thread discusses it and relevant fuses etc
https://www.fullfatrr.com/forum/topic57903.html 2010 VSE [Roger]
Post #579672 13th Jan 2021 10:41pm
DrRob
radio silence Whistle Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579696 14th Jan 2021 8:35am
Goodluck247
Thanks all for your replies!
In regards to the interior lighting, its absolutely everything in the front including the illuminated tread plates. I will try pressing and holding the main switch for around three second to see if it is the simple case that continuous off has been triggered.
As to the heater blower - all the switches and lights on the control work as they should and a believe it is heating up as if you put your hand to the vents they do feel warm. Would a fuse case an intermittent problem with the blower?
Does the bonnet always have to be open in order to check the oil level?
Post #579705 14th Jan 2021 9:41am
mjdronfield
No, bonnet can be shut for oil level. I think what was being touched on is that there is a sequence to follow to force it to tell you if you are outside the normal check period. I’ve never had to do that in 5 years. Just leave it for 15 or 20.... ignition on.... go into the display and it should show you.
I can’t see a fuse causing an intermittent problem. It’s either blown or it’s not. Sounds like FSR to me....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #579708 14th Jan 2021 9:51am
DrRob
Blower fuse = check it in boot to make sure it's not blown. You may need a multimeter to check it once removed.
Oil = no bonnet does not need opening unless you want to "cheat" it and use the double cancel route.
It should work cold or 20min post hot switch off as per the manual = ign on, go into menu. Let it stabilise when reading too. There is a YouTube video or 2 as well
Post #579709 14th Jan 2021 9:53am
Baltic Blue
Oil level,...
The bonnet open method is particularly useful when you are doing an oil change and need to keep checking to get the level right, because it saves time having to keep waiting 20 minutes for it to automatically reset.
Post #579710 14th Jan 2021 9:58am
Goodluck247
Few updates for you all. Oil level display is now working, I think it must of been due to me trying to check the oil level too soon after switching the engine off Laughing
Interior lighting - I tried pressing and holding the central button, after a few seconds the rear light flashes once however no activation of the lighting in the front. I have also noticed the reading lights don't work in the rear and the lights underneath the wing mirrors flicker. And more ideas on this one? Looking at the manual I downloaded, doe the central junction boxes ever produce a fault? I will check the light fitting in the front with a multimeter tomorrow to see if the fitting itself is drawing any power however it must be if it is still switching the rear interior light on and off?
Heater/blower - The intermittent blower yesterday is now completely dead today. unit definitely heats up as you can feel warmth around the vents. The rear blower also works fine. The more I'm thinking about this, the more I'm thinking this could well be the blower motor which has seized? I didn't get round to checking the fuse with a multimeter but I will do that tomorrow.
Post #579745 14th Jan 2021 4:12pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
When you put your lights on (side/main rather than interior) do you get anything from the 2 ambient LED's (you might need to hold your hand close to tell). I am assuming the you have checked the bulbs in the interior light unit too. Just wondering if these have been changed for LED's too and have blown or have thrown a fault 2011 TDV8 Vogue SE
Post #579750 14th Jan 2021 4:24pm
