Home > Maintenance & Mods (L405) > Topped up AdBlue, still telling me to top up? |
LT Member Since: 13 Mar 2017 Location: South West Posts: 397 |
I had the same problem with a 2016 D4. LRA sorted it out with a software update. Important, as it wouldn’t have started if I’d left it. |
6th Jan 2021 3:03pm |
E46ACS Member Since: 23 Sep 2020 Location: Durham Posts: 15 |
URGH 2017 Loire Blue 3.0TDV6 Vogue |
6th Jan 2021 3:14pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1096 |
What is the capacity, surprised it only took 4 Ltrs. The sensor says it is below X and only resets when absolutely full, its not like a fuel tank. Try filling up again. letters not necessarily in the right order |
6th Jan 2021 4:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
the diesel exhaust fluid [adblue] capacity is 18 litres so you probably havnt filled it up.. ... - .- -.
6th Jan 2021 4:20pm |
It seemed to have taken as much as it can, I'll give it another go. 2017 Loire Blue 3.0TDV6 Vogue |
6th Jan 2021 5:11pm |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
I have to put mine in quite slow or it will bubble up and over 2010 defender utility
6th Jan 2021 5:20pm |
ah, that could of been it. I'll give it a go in the daylight tomorrow. 2017 Loire Blue 3.0TDV6 Vogue |
6th Jan 2021 5:23pm |
Yes, airlocks seem to occur every time despite trying my best to fill it up smoothly. That's when parked on level ground. I did hear that if it's parked on an incline, it's even harder to fill up.
6th Jan 2021 5:38pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
Its worst of all if you park it on an incline with the back of the car pointing up hill! |
6th Jan 2021 5:50pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8550 |
Got a load of the proper screw in bottles off of tinternet, much more than the 10L tubs but much easier to fill.... There is nothing that can't be fixed with a hammer😜😜
6th Jan 2021 6:43pm |
I've never topped up this stuff...i believe its a job the dealer does on a service. ... - .- -.
6th Jan 2021 6:49pm |
I’m sure they do Stan, but suppose it depends on how far you drive between services.
6th Jan 2021 6:54pm |
Mine drains its tank from full in 6,000 miles, so it's less than half way to a service, but it's not far off the current oil change interval |
7th Jan 2021 10:01am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3814 |
According to the doomsayers I may not be able to drive into cities in the future but at least I don't have to worry about this stuff in the present. Geoff |
7th Jan 2021 10:26am |
