Home > Maintenance & Mods (L405) > Topped up AdBlue, still telling me to top up?
E46ACS
United Kingdom 2017 Range Rover Vogue TDV6 Loire Blue
Hi all, newbie here.
17 Plate 3.0 TDV6 Vogue, got the 'Refill DEF required' message came up. Bought 10l and topped it up, reckon it took about 4l to fill up. Service indicator was saying 621 miles to DEF service when I did this. This was 3 days ago and I've probably only done about 20 miles since the top up. Its still telling me to top and now its down to 541 miles to DEF service.
What have I missed?
Post #578624 6th Jan 2021 9:49am
LT
I had the same problem with a 2016 D4. LRA sorted it out with a software update. Important, as it wouldn’t have started if I’d left it.
Post #578663 6th Jan 2021 3:03pm
E46ACS
URGH Sad 2017 Loire Blue 3.0TDV6 Vogue
Post #578667 6th Jan 2021 3:14pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
What is the capacity, surprised it only took 4 Ltrs. The sensor says it is below X and only resets when absolutely full, its not like a fuel tank. Try filling up again. letters not necessarily in the right order
Post #578673 6th Jan 2021 4:03pm
the diesel exhaust fluid [adblue] capacity is 18 litres so you probably havnt filled it up.. ... - .- -.
Post #578674 6th Jan 2021 4:20pm
E46ACS
It seemed to have taken as much as it can, I'll give it another go. 2017 Loire Blue 3.0TDV6 Vogue
Post #578690 6th Jan 2021 5:11pm
bear100
I have to put mine in quite slow or it will bubble up and over 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #578698 6th Jan 2021 5:20pm
E46ACS
ah, that could of been it. I'll give it a go in the daylight tomorrow. 2017 Loire Blue 3.0TDV6 Vogue
Post #578699 6th Jan 2021 5:23pm
LT
Yes, airlocks seem to occur every time despite trying my best to fill it up smoothly. That's when parked on level ground. I did hear that if it's parked on an incline, it's even harder to fill up.
Hopefully that's the problem anyway. Thumbs Up
Post #578704 6th Jan 2021 5:38pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Its worst of all if you park it on an incline with the back of the car pointing up hill!
Post #578709 6th Jan 2021 5:50pm
Got a load of the proper screw in bottles off of tinternet, much more than the 10L tubs but much easier to fill.... There is nothing that can't be fixed with a hammer😜😜
Post #578725 6th Jan 2021 6:43pm
I've never topped up this stuff...i believe its a job the dealer does on a service. ... - .- -.
Post #578730 6th Jan 2021 6:49pm
I’m sure they do Stan, but suppose it depends on how far you drive between services.
Mine would probably have reached to the service but the OCD kicked in.... There is nothing that can't be fixed with a hammer😜😜
Post #578733 6th Jan 2021 6:54pm
Red Merle
Mine drains its tank from full in 6,000 miles, so it's less than half way to a service, but it's not far off the current oil change interval Sad
Post #578786 7th Jan 2021 10:01am
supershuttle
According to the doomsayers I may not be able to drive into cities in the future but at least I don't have to worry about this stuff in the present. Geoff
Post #578791 7th Jan 2021 10:26am
