Home > Technical (L322) > Total shutdown with no power whatsoever. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
What do you mean by a short flash from the parking brake? |
30th Dec 2020 10:39am |
bigfatbloke Member Since: 08 May 2018 Location: London Posts: 37 |
Just that really. It went on for perhaps a second, and then went off with everything else.
30th Dec 2020 10:56am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Could quite easily be an alternator failure... Im guessing the battery light was not illuminated whilst you sat there allowing the car to warm up? |
30th Dec 2020 11:00am |
Do the headlights work? |
30th Dec 2020 11:02am |
Nothing works. No lights interior or exterior. |
30th Dec 2020 11:08am |
That’s the thing, everything was looking normal. There was no warning, just instant shutdown. The engine had been running for perhaps a minute or so. |
30th Dec 2020 11:11am |
The only thing to do is put a fresh (charged) battery on her, then check the charge rate is climbing above 14v... Thats the place to start sir... |
30th Dec 2020 11:12am |
I am hoping that it is just the alternator too. I had to have the battery replaced 18 months ago because the previous one failed as well.
30th Dec 2020 11:20am |
30th Dec 2020 11:26am |
Thank you gentlemen, my mind is a bit more settled than it was when it happened. Then I was in full on gutter language mode and bouncing off the ceiling!!
30th Dec 2020 11:41am |
If you have a battery charger it would be worth trying to charge the battery, if you were able to do this your car should go back to normal for a while at least.
30th Dec 2020 12:00pm |
Thanks for assistance sir, it’s very much appreciated!! |
30th Dec 2020 12:21pm |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 |
sounds like the battery terminals. give them both a wobble to make sure they are tight .. |
30th Dec 2020 12:41pm |
Will give that a try. Thanks for the advice, and let’s hope it’s a cheap fix. 👍🏻 |
30th Dec 2020 2:32pm |
