Home > Technical (L322) > Xenon headlights L322 2004 mod |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Multi tester and test power out put on wiring. Could be you've got a break in the wiring that's reducing the power so to speak.
10th Dec 2020 11:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
What bulbs did you fit? Did you go for a like for like replacement? Or did you try a more blue looking route? |
10th Dec 2020 11:05pm |
Svennis Member Since: 23 Aug 2016 Location: Stavanger Posts: 9 |
I went for sone bulbs with «more» light I believe they should have a more daylight look and believe it was called D2S 5000k.
11th Dec 2020 5:53am |
In that case do you have the original bulbs still? Maybe refit them and have it re-tested?
11th Dec 2020 9:05am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Totally agreed. That daylight look is terrible for effectiveness. Even worse on these wet dark evenings. Sure the eye and mind gets tricked into thinking it’s good but it isn’t really. A warmer light bulb; around 4300K will provide much better results. |
11th Dec 2020 9:04pm |
