Home > Technical (L322) > Xenon headlights L322 2004 mod
Svennis
Norway 2004 Range Rover Vogue Td6 Barolo Black
Hello.
I have a L322 2004 mod with xenon headlights.
Had my Car for an EU-controll(believe you call it an MOT), where the mechanic told me that the headlights didn’t give enough lumen(light). I’ve newly change the bulbs, so I don’t believe these to be the problem. Anyone that have had these kind of problems? And please do come with tips and tricks;-)
Best regards
Svennis from Norway
Post #575690 10th Dec 2020 7:46pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Multi tester and test power out put on wiring. Could be you've got a break in the wiring that's reducing the power so to speak.
Get a power probe and light the light up with out car power and see if there's any light improvement
Post #575707 10th Dec 2020 11:02pm
What bulbs did you fit? Did you go for a like for like replacement? Or did you try a more blue looking route?
Post #575709 10th Dec 2020 11:05pm
Svennis
I went for sone bulbs with «more» light I believe they should have a more daylight look and believe it was called D2S 5000k.
Best regards
Svennis
Post #575719 11th Dec 2020 5:53am
In that case do you have the original bulbs still? Maybe refit them and have it re-tested?
Some of these "new style" bulbs off eBay trick the eye into thinking theres more light because of a colour difference when actually they give out less light on a meter than standard bulbs! Thumbs Up
Post #575724 11th Dec 2020 9:05am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Totally agreed. That daylight look is terrible for effectiveness. Even worse on these wet dark evenings. Sure the eye and mind gets tricked into thinking it’s good but it isn’t really. A warmer light bulb; around 4300K will provide much better results.
Post #575777 11th Dec 2020 9:04pm
