Home > In Car Electronics (L322) > Is Bovee 1000 the only option?
Mike220
Evening all. As per the title really, is the Bovee the only option for Bluetooth streaming on a 2011 FFRR? Or are there other routes available?
Cheers 2011 Vogue SE Tdv8 FFRR
Post #574562 29th Nov 2020 8:06pm
t5pete
I've got the airdual from amazon around the same price and I cannot fault it
Post #574575 29th Nov 2020 10:05pm
Jayk69
i think you can load mp3's on a usb and plug that in next to the ipod port 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #574596 30th Nov 2020 8:22am
Mike220
Will have a look at the airdual, thanks Pete
Yes I've got the mp3 sorted, need an option to stream via Bluetooth 2011 Vogue SE Tdv8 FFRR
Post #574603 30th Nov 2020 9:03am
Archieatkins
2007 Range Rover Vogue TDV8 Java Black
I got this for my 2007 with aux input, absolutely brilliant. As long as its plugged into the 12v it goes into standby when not in use and powers up when the ignition starts and automatically connects to your phone, I then stream from spotify or listen to audio books - sound quality is brilliant too.
https://www.amazon.co.uk/gp/product/B07CJ9...&psc=1
Post #574606 30th Nov 2020 10:01am
Mike220
Thanks Archie, certainly a low cost option. I assume all control must be done from your phone though? So no integration of the steering wheel controls etc. as per the Bovee (as the car thinks your phone is then an iPod)? 2011 Vogue SE Tdv8 FFRR
Post #574609 30th Nov 2020 10:29am
Archieatkins
yes your right, the only steering wheel integration is the volume, no skip track. However as I use Waze on my phone for almost all journeys I have my phone in a bracket anyway so it personally wasn't a deal breaker for me (also being a 2007 i had no usb option Laughing )
Post #574610 30th Nov 2020 10:33am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I have the Invery in mine. Almost certain track skip etc works.
No text display on screen but other than that works as any the Bluetooth streaming car interface.
Post #574614 30th Nov 2020 11:18am
Mike220
Thanks JNC, got a link to your particular one? Sounds like it does the same as the Bovee 2011 Vogue SE Tdv8 FFRR
Post #574615 30th Nov 2020 11:20am
JNC
https://www.amazon.co.uk/dp/B07RMHVJ6P/ref...&psc=1
Works faultless in 2011.
My phone connects to both the car Bluetooth for calls and that unit for music simultaneously.
Post #574617 30th Nov 2020 11:25am
Mike220
Thanks JNC, interesting. That's what I want ideally, music via a BT dongle and hands free via the car system as it works so well.
Looks like £66 direct from the airdual site too, not sure if any import duty though so need to check.
Am I right in thinking this is the same unit as the Bovee under a different brand name? Looks suspiciously similar at first glance 2011 Vogue SE Tdv8 FFRR
Post #574621 30th Nov 2020 11:56am
Philip
Yes, the same.
Post #574624 30th Nov 2020 12:19pm
Mike220
Thanks Philip 2011 Vogue SE Tdv8 FFRR
Post #574630 30th Nov 2020 1:18pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
JNC wrote:
https://www.amazon.co.uk/dp/B07RMHVJ6P/ref=cm_sw_em_r_mt_dp_0ynXFbX6C3YG7?_encoding=UTF8&psc=1
I also have this exact device and it works great!
(Caveat emptor, I didn't use it much as I ended up putting the Naviplus in, but it worked fine when I had it and I've a similar device in my other car which works great)
Post #574671 30th Nov 2020 7:38pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Surely if the text doesn’t display using the Invert then it can’t be the same as the Bovee since the bovee does display the test Wink
Post #574708 30th Nov 2020 10:43pm
