Home > In Car Electronics (L322) > Is Bovee 1000 the only option? |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
I've got the airdual from amazon around the same price and I cannot fault it |
29th Nov 2020 10:05pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i think you can load mp3's on a usb and plug that in next to the ipod port 2012 Vogue 4.4 TDV8 - Current
30th Nov 2020 8:22am |
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 |
Will have a look at the airdual, thanks Pete
30th Nov 2020 9:03am |
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 129 |
I got this for my 2007 with aux input, absolutely brilliant. As long as its plugged into the 12v it goes into standby when not in use and powers up when the ignition starts and automatically connects to your phone, I then stream from spotify or listen to audio books - sound quality is brilliant too.
30th Nov 2020 10:01am |
Thanks Archie, certainly a low cost option. I assume all control must be done from your phone though? So no integration of the steering wheel controls etc. as per the Bovee (as the car thinks your phone is then an iPod)? 2011 Vogue SE Tdv8 FFRR |
30th Nov 2020 10:29am |
yes your right, the only steering wheel integration is the volume, no skip track. However as I use Waze on my phone for almost all journeys I have my phone in a bracket anyway so it personally wasn't a deal breaker for me (also being a 2007 i had no usb option ) |
30th Nov 2020 10:33am |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I have the Invery in mine. Almost certain track skip etc works.
30th Nov 2020 11:18am |
Thanks JNC, got a link to your particular one? Sounds like it does the same as the Bovee 2011 Vogue SE Tdv8 FFRR |
30th Nov 2020 11:20am |
https://www.amazon.co.uk/dp/B07RMHVJ6P/ref...&psc=1
30th Nov 2020 11:25am |
Thanks JNC, interesting. That's what I want ideally, music via a BT dongle and hands free via the car system as it works so well.
30th Nov 2020 11:56am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2586 |
Yes, the same. |
30th Nov 2020 12:19pm |
Thanks Philip 2011 Vogue SE Tdv8 FFRR |
30th Nov 2020 1:18pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 |
I also have this exact device and it works great! (Caveat emptor, I didn't use it much as I ended up putting the Naviplus in, but it worked fine when I had it and I've a similar device in my other car which works great) |
30th Nov 2020 7:38pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Surely if the text doesn’t display using the Invert then it can’t be the same as the Bovee since the bovee does display the test |
30th Nov 2020 10:43pm |
