Home > Maintenance & Mods (L322) > help please. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
The second pic is supposed to be like that, it’s a breather for the gearbox or diff, so they don’t drown when wading. Can’t help with first pic though.
17th Nov 2020 11:59am |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 |
Phew thanks |
17th Nov 2020 12:03pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 |
That looks very similar to the breather pipe that comes out of the side of the battery. |
17th Nov 2020 6:14pm |
Sorted thanks |
18th Nov 2020 4:45pm |
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 |
Make sure that filter isn't a one way filter. Breather pipes allow air to escape when things get hot and then allow air back in when they cool down. If it has a check valve built in it'll either let air out but not back in or air in but not out. If air can't move freely in or out then oil gets forced out passed the oil seals or air/water/muck gets sucked in. Easy way to check is to pull it off the pipe and put it to your mouth and blow through it, then suck if you can do both all's good, put it back on, if not replace it with one without a check valve. |
19th Nov 2020 6:51pm |
Thanks I’ll do that tomorrow |
19th Nov 2020 6:55pm |
