Home > Maintenance & Mods (L322) > help please.
Ianb4310
help please.
I’ve been cleaning in the engine bay (I know I shouldn’t) anyway I think I’ve dislodged some pipe work and I’ve no idea where it should go
This was hanging loose at the back right hand side of engine anyone have any idea what it is ??
This is a inline fuel filter I think but there’s no pipe on the bottom of it and I can’t find one either
HELP
Post #573181 17th Nov 2020 11:30am
mjdronfield
The second pic is supposed to be like that, it’s a breather for the gearbox or diff, so they don’t drown when wading. Can’t help with first pic though.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #573185 17th Nov 2020 11:59am
Ianb4310
Phew thanks
Post #573186 17th Nov 2020 12:03pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
That looks very similar to the breather pipe that comes out of the side of the battery.
Post #573246 17th Nov 2020 6:14pm
Ianb4310
Sorted thanks
Post #573338 18th Nov 2020 4:45pm
Norm
Canada 2008 Range Rover HSE 4.4 V8 Alaska White
Re: help please.
Make sure that filter isn't a one way filter. Breather pipes allow air to escape when things get hot and then allow air back in when they cool down. If it has a check valve built in it'll either let air out but not back in or air in but not out. If air can't move freely in or out then oil gets forced out passed the oil seals or air/water/muck gets sucked in. Easy way to check is to pull it off the pipe and put it to your mouth and blow through it, then suck if you can do both all's good, put it back on, if not replace it with one without a check valve.
Post #573473 19th Nov 2020 6:51pm
Ianb4310
Thanks I’ll do that tomorrow
Post #573475 19th Nov 2020 6:55pm
