![]() | Home > Technical (L322) > ABS Fault FIXED!!!!! |
Mad Mac II Member Since: 13 Nov 2020 Location: Ramsgate Posts: 8 ![]() ![]() |
Well the problem still exists... so today im checking the continuity of the wires from the abs sensors to the ABS control module ..to eliminate the possibility of a bad connection or broken/damaged wires ...wish me luck |
I forgot to mention that i have a speed sensor 'A' fault on the transmission. Which i presume is a knock on effect from the NSF abs fault |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1369 ![]() ![]() |
Are you 100% certain that you fiited the correct sensor, they change over different years/models |
Im lead to believe i have the correct sensor now... its a 2007 vogue ABS sensor (green male plug) part number SSF500011.
continuity on the ABS sensor wires to the ABS control module is good ...
With a multimeter check out the resistance on the speed sensor and compare against the opposite one.
Checked the resistance and they are almost exactly the same ..... |
At least you can now discount the possibility of a duff or wrong sensor now
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 22 ![]() ![]() ![]() |
Is it a genuine sensor you’ve fitted? I only ask as I’ve had the wires round the wrong way on a Ford Focus rs one , or can you swap over left to right to try to eliminate other components. |
OK fixed!!!! I changed the wheel bearing and inner hub assembly.... the small brass tube in the ABS sensor (the tube the fixing bolt goes through to secure the sensor) was protruding so i took a file to it just to make it all level .... just ran it round the block and no more faults!!!!
if this post helps you sort out your problem leave a comment :d |
