Home > Technical (L322) > ABS Fault FIXED!!!!!
Mad Mac II
Good morning all and thank you for allowing me to join.
I have a 2007 L322 that I have just replaced the steering rack and now have an issue with the NSF ABS ....i changed the sensor TWICE! ...still the same ... fitted a new drive shaft as the abs ring looked worn and out of shape ...still the same ... reset the steering angle ... still the same and now at a loss .....could be the wiring ......and that's where I'm about to look now.. had live data via Hawkeye and reads the wheel speed up until about 15mph then reads zero and the fault appears
But any ideas or help would be gratefully appreciated TIA
Post #572659 13th Nov 2020 10:54am
Mad Mac II
Well the problem still exists... so today im checking the continuity of the wires from the abs sensors to the ABS control module ..to eliminate the possibility of a bad connection or broken/damaged wires ...wish me luck
Post #573134 17th Nov 2020 8:54am
Mad Mac II
I forgot to mention that i have a speed sensor 'A' fault on the transmission. Which i presume is a knock on effect from the NSF abs fault
Post #573136 17th Nov 2020 8:59am
dingg1
Are you 100% certain that you fiited the correct sensor, they change over different years/models
Post #573142 17th Nov 2020 9:27am
Mad Mac II
Im lead to believe i have the correct sensor now... its a 2007 vogue ABS sensor (green male plug) part number SSF500011.
Thank you for taking the time to reply
Post #573189 17th Nov 2020 12:36pm
Mad Mac II
continuity on the ABS sensor wires to the ABS control module is good ...
Could the tracking be out and have an adverse effect on the ABS reading?
Post #573299 18th Nov 2020 10:39am
dingg1
With a multimeter check out the resistance on the speed sensor and compare against the opposite one.
Fronts and rears may be different.
Just to make sure it isn't a Censored or incompatible sensor, been there myself...
Post #573304 18th Nov 2020 12:17pm
Mad Mac II
Checked the resistance and they are almost exactly the same .....
Post #573581 20th Nov 2020 2:18pm
dingg1
At least you can now discount the possibility of a duff or wrong sensor now
Good luck
Post #573626 21st Nov 2020 8:29am
Jri711
United Kingdom 2010 Range Rover Vogue 4.4 V8 Santorini Black
Is it a genuine sensor you’ve fitted? I only ask as I’ve had the wires round the wrong way on a Ford Focus rs one , or can you swap over left to right to try to eliminate other components.
Post #573628 21st Nov 2020 8:57am
Mad Mac II
OK fixed!!!! I changed the wheel bearing and inner hub assembly.... the small brass tube in the ABS sensor (the tube the fixing bolt goes through to secure the sensor) was protruding so i took a file to it just to make it all level .... just ran it round the block and no more faults!!!!
hope this post goes some way to help others in similar situations...David
Post #573822 23rd Nov 2020 2:45pm
Mad Mac II
if this post helps you sort out your problem leave a comment :d
Post #574323 27th Nov 2020 4:28pm
