Home > Technical (L322) > Improve FBH 2011
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Improve FBH 2011
My 2011 came with remote FBH. All seems to work as expected. But never seems to be warm. Confused
Post #571976 6th Nov 2020 10:48am
DrRob
I'm convinced that turning the temperature dials up to max the night before makes a difference...
Try it and let me know Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #571978 6th Nov 2020 11:01am
JNC
Tried that. Still not even slightly warm.
Post #571979 6th Nov 2020 11:02am
AJL322
Scotland 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
The FBH will only put out warm air if the ambient temp is below 5*C I believe.
I set the timer on mine and its still blowing cold but when its really cold outside it will defrost the car before I get out to it.
Post #571982 6th Nov 2020 11:20am
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi, the fan will blow warm air into the cab if the outside temp is 16 degrees or less, if the temp is above 16 the hvac will blow cold air into the interior to cool it down, if the temp outside is less than 6 degrees it will blow warm air into the interior and pump warm water around the engine block to aid cold starting. I'm with Dr Rob and think it works better if the dials are turned up, remember it will take upto 20 minutes to fully heat the interior.
Post #572004 6th Nov 2020 7:43pm
mjdronfield
If the weather is hot, it just blows the outside air in, rather than cold, so at least the interior isn’t any hotter than outside.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572010 6th Nov 2020 8:32pm
flexfly
Re: Improve FBH 2011
Same in my 2012. But my old 07 got properly warm. Still defrosts the car so not complaining, it’s just not toasty warm like I expected 2012 RR Westminster TDV8
2008 Audi S5 4.2 V8
2006 Mazda MX-5 R/C Sport 2.0
Gone...
2007 RR Vogue SE 3.6 TDV8
2005 Ford Focus LX tdci 90
2006 Mazda RX-8
1996 Land Rover Discovery 300tdi
1998 BMW 523i
Post #572018 6th Nov 2020 10:15pm
JNC
How long should it run for at a time? I tried it this morning as the temp was less than 6 degrees.
The fob flashes green for some time, when it stopped I pressed it again. Repeated several times, I guess the run time would have been 30 minutes or so.
Got in the vehicle and heater was still cold.
I have had to change coolant within last 6 months, I wonder if that side of the system has an airlock?
Post #572022 6th Nov 2020 10:42pm
DrRob
My first was a 1952 80" Land Rover that I rebuilt myself. No heater and massive gaps around doors and windscreen. No draughts is enough for me Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #572023 6th Nov 2020 10:50pm
JNC
This is true. But its quite a kit to have fitted if it doesn't even do anything.
Post #572024 6th Nov 2020 10:51pm
mjdronfield
I think the one on my TD6 run for 30 mins, but I’ve a feeling it’s 20 mins on the 4.4 TDV8.
It will stop if criteria is met, like low fuel or battery voltage low.
I have the manual for the heater somewhere, and there are things you can configure, if I remember right.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #572025 6th Nov 2020 10:56pm
JNC
I tried to find manual but drew blank.
Post #572026 6th Nov 2020 11:00pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #572027 6th Nov 2020 11:03pm
JNC
Perfect, thanks.
Will give it a try.
Post #572028 6th Nov 2020 11:05pm
mjdronfield
Mine doesn’t get that warm to be fair. And I assume it would defrost the windows, but my car is inside, so I’ve never tested it for that.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #572030 6th Nov 2020 11:09pm
