Home > Technical (L405) > Rumble from front offside at 70-85mph - driveshaft issue
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
I just thought I would share the issue I had with my FF. For some time I noticed there was a rumbling from the front offside corner when accelerating at between 70-85mph. I had the wheels balanced, checked the pressures and looked underneath to see if there was anything obvious but to no avail. @2 weeks ago the rumble became much worse. It was loud and it could be felt through the steering even at slow speeds especially when going over bumps or pot holes.
I did no more than take it to my local independent who, after inspection diagnosed a damaged offside front drive shaft. There seemed to be no reason behind this - both CV boots in place and full of grease - but 2 days later a new drive shaft fitted had cured all the problems. Thank goodness for my warranty! Thumbs Up 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #571711 3rd Nov 2020 1:33pm
thanks for the info.. Thumbs Up ... - .- -.
Post #571720 3rd Nov 2020 2:12pm
