Home > General > Fed up with 2011 Battery Drain |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35106 |
take it to the dealer and get your money back....either take a big stick with you or a solicitor.. ... - .- -.
24th Apr 2011 7:49pm |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 |
I love it though Where do I stand legally? It's had various other faulty electronics replaced already. |
24th Apr 2011 7:51pm |
i dont know how you stand legally but how about sitting down with the sales manger and explaining the problems and see what kind of solution he can offer...like you say its a £90k car and there's a chance you will spend at this dealer again so the sales manager would be a pratt not to sort this out for you..
24th Apr 2011 8:01pm |
Thank you, scarey. Its going in again for one last chance. Let's hope this fixes it. I suppose it could be that the low battery warning is oversensitive and just panicking me. Sadly I don't think it is |
24th Apr 2011 8:04pm |
the weather is lovely and warm at the moment so the battery hasn't got a lot to do but, wait till it gets cold then it will fail.. good luck at the dealer. ... - .- -.
24th Apr 2011 8:08pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
there is a recall on 11 and 11.5 MY cars speak to your dealer , new battery and new software , mine did the same fir the first 700 miles , not had it once since i put it on deep charge myself for 2 days and now at 1600 miles no problems , but still going with the recall to be safe. Far to many gone... |
24th Apr 2011 8:45pm |
Thanks very much for the insight! Is this sort of an unofficial recall? I thought I would be contacted? |
24th Apr 2011 8:59pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Sorry to hear about your problem.
24th Apr 2011 9:06pm |
Think it's all 2011 models. But Diesels use more power to start. |
24th Apr 2011 9:10pm |
It will go official , but have a good relationship with my dealer
24th Apr 2011 10:24pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 789 |
so on a cold frosty morning, the pre-heater is now meant to do its job in less than 10 minutes when previously it took 30? How come? Has its heating capacity suddenly been tripled?
25th Apr 2011 10:36am |
I think they also alter the heating cycle so it uses the same amount of fuel to give more heat in a shorter time if that is the case better IMO Far to many gone... |
25th Apr 2011 11:29am |
Not possible, the webasto heater is already at full throttle after its initial start cycle which takes 1-2 minutes, then it goes through its power down/ cooling cycle for the last 5 minutes. So if they are saying the car can be fully up to temperature after 3 minutes of full burn then I'll eat my hat! It's really quite simple, the current draw of th FBH is VERY low. The FBH is not the issue, however it may be the straw that brakes the camels back. It would be more to the point if LR UK found the cause of the drain (not the dealers, because lets face it, they don't give a hoot). The P38 went for years with constant battery drain that turned out to be the alarm RF receiver waking the car up. |
25th Apr 2011 1:43pm |
The dealers don't give a hoot?
25th Apr 2011 1:56pm |
