Home > General > Fed up with 2011 Battery Drain
Page 2 of 3 <123>
johnson1
Rambles wrote:
The dealers don't give a hoot?
Amen to that...
Yes Sad
The car isn't being driven today. Tomorrow morning could be fun. The red alarm LED is still flashing on the dash - does this mean it isn't flat yet???
Post #61473 25th Apr 2011 12:59pm
Rambles
so I tried the remote heater this morning as it was6 degrees.
It ran for just over 10 minutes and then shut down.
Difference it made to cabin temp?
none.
sweet fa difference.
and driving off, the radiator temp was cold, and took same time as usual to warm up - so i guess the mod has been to disable the remote heater.
Post #61765 28th Apr 2011 6:25am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
What temp did you set on the remote heat ? Far to many gone...
Post #61767 28th Apr 2011 6:56am
Rambles
what do you mean what temp did I set on the remote heat ?
It will heat up to 15 degrees as per the handbook. The temp is not settable.
Post #61773 28th Apr 2011 7:50am
tboner001
agh ok i thought on my 11.5 that you could pick the heat required via the temp control Far to many gone...
Post #61776 28th Apr 2011 8:02am
johnson1
You can...on 11.5.
Post #61780 28th Apr 2011 8:08am
Rambles
OK - so as I have the MY11, it should heat to 15 degrees.
Post #61783 28th Apr 2011 8:21am
johnson1
Rambles wrote:
how does that work pls? My RR is the 11.5, and there is no mention in the handbook about changing the temp setting.
page 62 and 120 in the handbook refer to the heater. I can't see anything there that says you can use the internal temperature setting.
Anyway - my internal temp setting was 19 degrees.......so this doesn't help.
And the dial doesn't go below 16 degrees....so am I missing something?
You're right it doesn't mention it! I was told in handover though that just adjust the temp setting and that'll sort it. BUT, I haven't actually used it...
Post #61786 28th Apr 2011 8:59am
dan_uk_1984
I thought it would heat as long as the temperature was below 15 degrees outside? Not heat the cabin to 15 degrees? Have you seen info to the contrary? (I'm only going on the earlier models behaviour though)
The FBH unit will cut out if voltage falls below 11.4V. Also, a 10 minute run will never heat the cabin as the changeover valve only opens when the coolant reaches a set temperature in the engine first.
I think the temperature guage on the dash starts at 50C so you wont see the dial move unless the FBH gets a full 30 minute run.
Post #61791 28th Apr 2011 9:18am
Rambles
I changed my post as I just checked with LR and my model is actually the 11, not the 11.5.
Doesn't change my problem though that either way, it cuts out after 12-14 minutes, and heats not.
Post #61792 28th Apr 2011 9:22am
Rambles
sorry to ask a dumb question.
you talk FBH...I talk webasto.
what's the difference?
Post #61793 28th Apr 2011 9:23am
dan_uk_1984
The Webasto is a Fuel Burning Heater. Much like the Range Rover is a 4x4.
Post #61797 28th Apr 2011 9:55am
dan_uk_1984
As per my above post - it will stop short of a full run if the battery voltage drops below 11.4V. You could test this with a multimeter across the battery terminals or jump points to see if the voltage is indeed dropping below this threshold.
Also, as I said above, the engine is heated first, this generally takes about 15/20 minutes from experience (depending on the start temperature of the block). Then in the last 10 minutes the bypass valve opens and then heats the interior.
Post #61798 28th Apr 2011 9:58am
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
Rambles
I had an issue with my FBH before Xmas, it would fire up and not heat the cabin. It was only heating the engine block, indicating the HVAC was not initiating the changeover valve to move to the cabin setting and start the fans to circulate the warm air.
Guava traced it to a software issue on the HVAC (heating ventilation air conditioning system). Land Rover supplied updated software for the HVAC and it works fine now.
I have fixed my occasional flat battery by putting a battery conditioner on when the FFRR if laid up for a few days if I am away on business or using another vehicle. I connect it to the permanent live power socket in the boot. I have conditioners on all the Land Rovers so there is never an issue with any of them starting. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #62003 28th Apr 2011 7:41pm
Rambles
so yesterday I put the battery onto charge with a charger / conditioner.
once battery fully charged (took about 6 hrs using a Ctek XS7000) i took off the charger.
this morning, i use the FBh....
and guess what
somehow the battery has gone flat overnight, and within 5 minutes the FBH has shut down to preserve the battery.
and this is on a car which is meant to have had "the fix".
well I am completely fed up....
Land Rover.....if you scan these threads....you have one customer in me who may not be buying LR again in the future unless this problem is rapidly recognised (the chap on the help line yesterday was in denial......) and fixed.
Post #62044 29th Apr 2011 5:55am
Page 2 of 3 <123>
