Home > Wheels & Tyres > 275-55-20 tyres on L405?
LT
Is anyone running 275-55-20 tyres on their L405?
Any rubbing issues? Will the spare wheel still fit in with this size tyre fitted?
Thanks Thumbs Up
Post #570380 20th Oct 2020 10:51am
Vogue
285/50/20 fit fine and they are wider - also just fit in the tyre well. 275/55 are 18mm dia larger - they will fit but not sure if the spare will fit in the tyre well 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570411 20th Oct 2020 5:20pm
LT
Thanks, Thumbs Up
I've been playing around with a tyre size calculator, the width of a 275-55-20 tyre is the same as the 275-45-21. So as you say, that won't be a problem. The diameter might be though?
Post #570413 20th Oct 2020 5:35pm
Vogue
The difference is only 9mm in the radius - not 18 which is the diameter - a lot will depend on the manufacturer of the tyre - my 285/50/20 are far taller than regular 285/50’s as they AT tyres with very deep tread and don’t accord with the normal size range of that tyre - I would suspect the 275’s will fit ok - if anything they may just catch on full lock.
If you can get the manufacturers circumference from their spec list of your chosen tyre I can measure mine here and that may help. Mine fit fine and also in the well - just 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570416 20th Oct 2020 6:06pm
LT
I'm a bit nervous about off road use this winter with the Pirelli Verdre All Seasons I have fitted. Although I didn't really worry them last winter, but then the only really muddy sections I drove were pretty much flat.
I'm not a fan of General Grabbers and Duratracs are too aggressive for my needs, so I was considering fitting a set of these for the winter:
https://www.coopertire.co.uk/tires/discoverer-at3-4s
I'll see if I can get some precise measurements. Thumbs Up
Post #570417 20th Oct 2020 6:13pm
Vogue
That’s what I have Cooper AT3 in 285/50/20 - these are my winter tyres for the shooting season and summer are 285/40/22 on Turbines. Why not just go for the 285/50’s and save any hastle - they fit without issue both in the car and in the tyre well. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570422 20th Oct 2020 6:43pm
LT
According to the Cooper website the AT3 4S isn’t available in that size:
https://www.coopertire.co.uk/tires/discove...mp;speed=K
Post #570433 20th Oct 2020 8:49pm
Vogue
Not sure what the 4S stands for - mine are AT3 Sport - there’s a piccy on this thread - last post on the page :-
https://www.fullfatrr.com/forum/topic20116-60.html 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570448 20th Oct 2020 10:08pm
LT
This is the link to the SUV/4X4 tyres from the Cooper U.K. website:
I couldn’t see any of the AT3 variants listed in 285-50-20
The 4S I assume stands for 4 seasons. I think that they may also be 3PMSF stamped.
Post #570495 21st Oct 2020 12:31pm
Philip
What about Goodyear All-Terrain Adventure? They’re OE for the new Defender.
Post #570501 21st Oct 2020 1:46pm
LT
Yeah, they’re very much on my radar and available in 275/55/20. With Kevlar reinforcement in that size as well. Not all sizes have the Kevlar.
Post #570509 21st Oct 2020 2:37pm
Vogue
Mmm maybe there is no stock at the moment - very much doubt they have stopped making them - have you tried Silverline?
Another option are Toyo 285/50/20 - I have a set of their tyres in a different size on a Defender and they are excellent https://www.ebay.co.uk/itm/274514905699 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570572 21st Oct 2020 8:05pm
Vogue
10 second google - the Coopers are listed here for sale, although they appear currently out of stock it shows Cooper are still making them in that size :
https://4x4tyres.co.uk/product/285-50-20-c...3CEALw_wcB
https://www.tyres-guru.co.uk/product/Coope...0/R-350515 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570573 21st Oct 2020 8:07pm
LT
Thanks. I also found them for sale (shown as out of stock), but my concern was more that Cooper had stopped manufacture or U.K. supply. I wanted to avoid buying a set and then find in the future that I can’t replace one due to them being no longer available.
Post #570609 22nd Oct 2020 7:17am
