Home > For Sale & Wanted > td6 starter motor wanted
i might be needing a td6 2005 pre-facelift starter motor soon..not absolutely sure it needs replacing but i'm just putting out the feelers...let me know if and how much if you have one spare. ... - .- -.
Post #61245 21st Apr 2011 7:54pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Are you having symptoms stan? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #61250 21st Apr 2011 8:27pm
Landrover Mad
2003 Range Rover Vogue Td6 Buckingham Blue
Hi Scarey,
Have you thought about getting it reconditioned, an auto electrician did mine last week, they fitted a new pinion as the clutch mechanism wasn't working correctly - only cost £80.
Symptoms: Car started first turn of the key sometimes then would just turn over and over other times.
Saying that a new one is only around £150
Stephen
Post #61266 22nd Apr 2011 8:03am
@hoppy...got a little 'screech' for a second when starting from cold, after that its ok..as this started after i went swimming with the range on salisbury plain, my son reckons its the bearing which has dried out..next step is to take out the starter , lubricate and refit...if this doesnt work then a new starter will be required...
@L.M. thanks for the info...there are secondhand ones on ebay for £40/50 and recons for £90'ish.. ... - .- -.
Post #61278 22nd Apr 2011 10:30am
