![]() | Home > Technical (L322) > 4.4 TDV8 injector codes - help please |
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 ![]() ![]() |
I managed to get an hour on the car tonight, made decent progress
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
normally I'd say brake cleaner but if cleaning parts on the car not too sure.
Thanks, Greg.
Help please...
not done this myself and I'm sure somebody who has will be along soon...
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
There a tab you have to push in and then pull up. |
As the top picture is now there's a green tab |
Sorry, forgot to mention the tab!
Odd thing is the workshop manual seems to suggest the whole thing can be removed from the donut without separating the pipes. Given it's a water pipe I don't know if the system will need bleeding afterwards if I do need to separate them?
It 100% separates ill see if I can find the old pipe I replaced on mine regarding bleeding no all should be fine I didn't have to bleed the system after removal. |
Just been out to work shop and got you a couple of pics
That's very kind of you, thank you.
No problem I hope the new hoses sorts your issues. |
Hoses are now replaced and everything got a major clean while it was disassembled. It's a wonder the engine runs with that much crap being recirculated back into the inlet.
