Home > Technical (L322) > 2004 FFRR binnacle display language change? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi - I can't confirm the setting (as I'm not with the car) but it is accessed via the Screen display on your sat nav. (assuming you have this)
20th Apr 2011 8:23am |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 |
im still struggling and google hasnt turned anything up yet
21st Apr 2011 11:34am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35273 |
dis-connect your battery for an ecu reboot.. ... - .- -.
21st Apr 2011 12:57pm |
tried poking around the nav interface (which is still English) and disconnect battery...but the pod display is still in French
23rd Apr 2011 8:37pm |
found this , hope it helps.
23rd Apr 2011 8:59pm |
cheers...that does take you into config, but its for the nav unit rather than the car itself
24th Apr 2011 8:57am |
then its a trip to the dealer i guess...i too wonder why it changes like that. ... - .- -.
24th Apr 2011 9:20am |
another electronic quirk ...a bit like the random reboots of the nav ...its got a mind of its own cheers
24th Apr 2011 1:53pm |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 |
Its via the nav - I can confirm as a nice garage (sic) in Spain reset it to French after a visit (as it is a French car - what logic!). Cleared via the nav screen and now is happily "speaking" the queens english |
28th Apr 2011 5:35pm |
..you mean what i suggested four posts ago steve? ... - .- -.
28th Apr 2011 6:01pm |
yeah, you can change the nav language via the nav settings
28th Apr 2011 7:35pm |
just a thought..the button you press [on the stalk] when you go from one reading to another, if you keep that button depressed for a few seconds ,does it go to a menu select screen on the nav, if so is there something that can be selected there... ... - .- -.
28th Apr 2011 7:41pm |
yep, that goes to "prog" where you can select all the values you may/may not want to see....but not the bleeding language its in ive been looking everywhere for some button combo press that may do it, but even google doesent have the answer cheers bogie |
28th Apr 2011 8:00pm |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
Hi chaps,
8th Dec 2015 10:07pm |
