Home > Technical (L322) > 2004 FFRR binnacle display language change?
bogie
ok, so driving along today and glance down...my binnacle display has turned into French ...very bizarre...no idea which buttons ive pressed ! Wink
anyone know how to get it back to English? cheers
bogie
Post #61047 19th Apr 2011 8:41pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi - I can't confirm the setting (as I'm not with the car) but it is accessed via the Screen display on your sat nav. (assuming you have this)
Go into the menu and look for the language setting. you should have GB highlightedand it should update the dash consol. Ash
2016 SDV8 AB
Post #61085 20th Apr 2011 8:23am
bogie
im still struggling and google hasnt turned anything up yet
workshop manual says I need testbook Sad cheers
bogie
Post #61192 21st Apr 2011 11:34am
dis-connect your battery for an ecu reboot.. ... - .- -.
Post #61196 21st Apr 2011 12:57pm
bogie
tried poking around the nav interface (which is still English) and disconnect battery...but the pod display is still in French Smile
I guess I will have to wait until it goes in next for a service...its not a big deal cheers
bogie
Post #61346 23rd Apr 2011 8:37pm
found this , hope it helps.
in the main screen, choose set. when in the set menu, press and hold the 'menu' button for 6-8 seconds,a new set of service commands will appear, scroll down to choose the language setting. ... - .- -.
Post #61348 23rd Apr 2011 8:59pm
bogie
cheers...that does take you into config, but its for the nav unit rather than the car itself
in the workshop manual to change language it says I need to use Test book ...but I cant figure out why it changed itself in the first place whilst im driving along ! LOL Wink cheers
bogie
Post #61370 24th Apr 2011 8:57am
then its a trip to the dealer i guess...i too wonder why it changes like that. ... - .- -.
Post #61372 24th Apr 2011 9:20am
bogie
another electronic quirk ...a bit like the random reboots of the nav ...its got a mind of its own Wink cheers
bogie
Post #61384 24th Apr 2011 1:53pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Its via the nav - I can confirm as a nice garage (sic) in Spain reset it to French after a visit (as it is a French car - what logic!). Cleared via the nav screen and now is happily "speaking" the queens english
Post #61936 28th Apr 2011 5:35pm
..you mean what i suggested four posts ago steve? ... - .- -.
Post #61941 28th Apr 2011 6:01pm
bogie
yeah, you can change the nav language via the nav settings
this is the instrument binnacle - below the speedo etc where you can program time/mileage/consumption etc
that has changed to French ...the nav itself is fine, all normal in English
its the vehicle language thats changed, and according the workshop manual, needs to be changed by Testbook software
whats puzzling is just how it changed itself at random during a journey....
will get it looked at next service, im in no rush...it might change itself back before then anyway LOL Wink cheers
bogie
Post #61996 28th Apr 2011 7:35pm
just a thought..the button you press [on the stalk] when you go from one reading to another, if you keep that button depressed for a few seconds ,does it go to a menu select screen on the nav, if so is there something that can be selected there... ... - .- -.
Post #62002 28th Apr 2011 7:41pm
bogie
yep, that goes to "prog" where you can select all the values you may/may not want to see....but not the bleeding language its in Sad
ive been looking everywhere for some button combo press that may do it, but even google doesent have the answer cheers
bogie
Post #62013 28th Apr 2011 8:00pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Hi chaps,
Bit of a thread resurrection going on here but it might be useful to someone.
I've got the mk4 navigation unit fitted and I upgraded the disk to sw version 4-1/01.
anyway, this comes with speed camera alerts which is useful when I'm in unfamiliar territory but annoying around my home area. I turned this feature off and all the binnicle messages changed to French. Shocked
Once reinstated I'm back to reading the Queens English, hooray.
also, the menu has 'memo'. Once activated it sets a beeper / alarm off at 1959hrs, whoopy Rolling Eyes
jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #361184 8th Dec 2015 10:07pm
