![]() | Home > For Sale & Wanted > [Wanted] Locating Clips for Load Space floor panel |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Try Powerful UK |
2nd Rower Member Since: 24 Sep 2009 Location: Upside Down Posts: 62 ![]() ![]() ![]() |
My understanding is these are not available separately. They come only as part of the load space floor. |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
if its just the lug which is broken you can drill a hole through the plastic and use a correct size nut and bolt.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3818 ![]() ![]() ![]() |
Good tip Stan,
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
I hear you Stan and Baltic, however the plastic is fatigued so best replace it.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Let the air out of your spare tyre and the lid should shut easily |
