Home > For Sale & Wanted > [Wanted] Locating Clips for Load Space floor panel
Range Rover L322
I need two of these. I cannot find them in any parts manual. I think they should unscrew from the floor-panel.
Post #567926 24th Sep 2020 5:25pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Try Powerful UK
Post #567954 24th Sep 2020 11:30pm
2nd Rower
Australia 2010 Range Rover Vogue SE TDV8 Zermatt Silver
My understanding is these are not available separately. They come only as part of the load space floor.
Post #567956 25th Sep 2020 12:59am
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
Just happened to have made some with my 3D printer, don't know how durable they will be but I have printed them in ASA (ABS type) £5 reasonable? 2010 3.6 TDV8
Post #568000 25th Sep 2020 4:54pm
if its just the lug which is broken you can drill a hole through the plastic and use a correct size nut and bolt.. ... - .- -.
Post #568001 25th Sep 2020 5:19pm
Baltic Blue
Good tip Stan,
An identical repair lasted at least 6years on my Td6 L322. Thumbs Up
I put a black heatshrink sleeve over the thread to finish off the fix.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #568008 25th Sep 2020 6:01pm
Range Rover L322
I hear you Stan and Baltic, however the plastic is fatigued so best replace it.
It didnt matter until I changed my tyres (and spare) to 255/55/20 so now the tyre sits slightly higher in the boot there and it's all a bit tight ...
Post #568018 25th Sep 2020 9:33pm
Let the air out of your spare tyre and the lid should shut easily Thumbs Up Then simply carry a cigarette lighter tyre inflation compressor, just in case you need to use the spare... Thumbs Up
Post #568024 25th Sep 2020 11:30pm
