![]() | Home > Maintenance & Mods (L322) > How to check shocks? |
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 ![]() ![]() ![]() |
The easy way is to get someone to drive your car and you drive alongside in another car and just look. If you have a shock gone you'll see the wheel bouncing up and down like crazy. Failing that the old way was to put all your weight on the affected corner and then let go, try and see if that corner bonces more than the others. It should settle in one or two bonces. |
ABY Member Since: 01 Dec 2019 Location: Northampton Posts: 26 ![]() ![]() ![]() |
I'm getting bounce now and feeling the bumps hard ! what's it going to cost to replace the rear shocks |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Has anyone else any experience on the front as I don’t know how to test with air - do they get noisy? I have 22s so I’m not sure if the ride is down to them or the shocks or both it didn’t always seem so bouncy but could be my imagination due to lockdowns |
